warpig12354
too slow
I've searched and didnt find a definite answer. My car has always had a slight steering wheel shake around 60+ but lately seems to have gotten worse. I'm almost positive my alignment is fine but I guess thats always a possibility. I recently got AMR wheel/tire combo 18x9/18x10 with 255/45-18 in the front and 275/40-18 in the rear, the front tire size didnt change from my last set up. When I initially got the wheels it seemed that the shake had almost gone away but within a few days it was back and seemed worse than before so I got them rebalanced (road force) and it didnt really do anything. When my hand is on the wheel it shakes my watch and I can see my radar detector moving on the wind shield. This happens from random speeds from 60-90, like at 76 its fine then I speed up or slow down and it vibrates/shakes. Then above 90 it feels solid. I have koni orange shocks/stuts, BMR springs and GT500 mounts. I never adjusted the pinion angle after lowering it but don't see that all the sudden being a bigger issue now (stock ds). I've also had the tie rods replaced with in the last ~20,000 miles. Car has about 103,000 miles on it if that helps. The rotor clips are also off so thats not the issue. Thanks for the help. Im going to get them rebalanced today to see if that helps any.
