Discussion in 'Home Improvement' started by Infamous05, Apr 11, 2013.
  1. slow06stang
    slow06stang Member
    34
    413
    Oct 7, 2009
    Arnold, MO
    Is it a frost free spigot? If so buy a rebuild kit from lowes, HD, or Menards. The washers are probably trashed. Those leaks make for a big water bill or a rough time for a well pump.
  2. GallopingFord
    GallopingFord I'm Cam - Mr. Indecisive
    15,350
    Sep 5, 2010
    Northern Virginia
    The previous home owners had the main water shutoff, turned off which leads me to belive that they knew there was an issue. I took off the wheel and shoved electrical tape in there just to keep minimal leaking while I washed my truck tonight. I'm not sure what a frost free spigot is? I normally turned my front and rear hose lines off during the winter.
  3. Gabe
    Gabe Whippled Coyote
    6,088
    Aug 7, 2011
    NH
    Frost-free spigot reaches into the house through the wall, shuts off the water inside the house so the cold weather doesn't affect it (as much). They're available in various lengths.
    [​IMG]
  4. GallopingFord
    15,350
    Sep 5, 2010
    Northern Virginia
    The trouble maker looks like this.
    [​IMG]
    Here's what the gaskets. looks like. Looks to me both of them need to be replaced - top one is getting raggedy and bottom one has a fold in it.
    [​IMG]
    Also made my grout cleaning tool tonight.
    Amazing what $3 can build you.
    [​IMG]
  5. slow06stang
    slow06stang Member
    34
    413
    Oct 7, 2009
    Arnold, MO
    That is a frost free spigot that is worn. Bring that with you, different manufactures have slight variances. New spigots are $20 and up the rebuild, I think runs $3-$8 and no soldering.
  6. AndrewNagle
    AndrewNagle forum member
    2,429
    9
    Jun 20, 2008
    Mountains of NC
    exactly
  7. GallopingFord
    15,350
    Sep 5, 2010
    Northern Virginia
    Sounds good. Going in a little bit to Lowes and will see what they have. Thanks for the help guys
  8. GallopingFord
    15,350
    Sep 5, 2010
    Northern Virginia
    Home Depot had a valve repair kit, and the front rubber seal helped but I went online and found the proper rebuild kit for the PRIER unit I have. Should see it beginning of next week.
  9. skwerl
    skwerl tree hugger
    14,919
    10
    Aug 6, 2011
    central Florida
    Hopefully you bought kits for all your outside spigots.
  10. oldVOR
    oldVOR forum member
    862
    Apr 9, 2015
    Northern Virginia
    I'd recommend having spares on hand since the local box stores don't stock them.
  11. GallopingFord
    15,350
    Sep 5, 2010
    Northern Virginia
    Yeah purchased a few. They arrived this morning, fixed the garage one first and presto it's perfect. Thanks again for the help guys.
  12. slow06stang
    slow06stang Member
    34
    413
    Oct 7, 2009
    Arnold, MO
    No problem. If you have cold winters, I would still recommend shutting it off inside in the winter.
  13. Gabe
    6,088
    Aug 7, 2011
    NH
    What he said.
    I shut mine off inside, then drain the outside and shut it off there too
  14. GallopingFord
    15,350
    Sep 5, 2010
    Northern Virginia
    Yeah, I've done that every year.
  15. Strengthrehab
    Strengthrehab forum member
    4,149
    Jun 25, 2013
    still cleaning up. Gonna pick up some wood to put over the rafters in the attic above the garage to get all of the storage stuff up there.
    What are y'all doing for shelves/wall storage?
    Sent from my SM-G950U using Tapatalk
  16. ksack
    ksack forum member
    1,502
    Feb 27, 2012
  17. slow06stang
    slow06stang Member
    34
    413
    Oct 7, 2009
    Arnold, MO
    I have some snap together metal shelves, wall cabinets hung, ceiling racks, some rubbermaid shelving units, some commercial shelving units. I acquired a bigger safe so I even use my old one in the garage for storage. All of mine were free even the safe, so it is nothing uniform.
  18. pass1over
    pass1over I like it LOW
    37
    815
    Oct 9, 2011
    Trenton, FL
    Nothing is uniform in my workshop either.
    I have some industrial racking from my old job (Fastenal), some lighter duty metal shelving units that I found on craigslist for dirt cheap, an old cd stand that I use for spray paints, and a couple of wire shelving units similar to what ksack posted, but not as tall. There's some wooden shelving on the wall for my tool kits, etc.
    Gotta figure if you want everything matching and uniform or cheap storage space. I'd keep an eye out of craigslist or letgo for people getting rid of the shelves, etc.
  19. Premium08
    Premium08 Need to Get Another Pony
    4,058
    Jun 7, 2011
    Littleton, NC (Lake Gaston)
    Installed a keypad deadbolt on our front door the other day. Enjoying it so far, might have to get one for the garage entrance door as well.
    Sent from my XT1585 using Tapatalk
  20. Strengthrehab
    4,149
    Jun 25, 2013
    Cleaned up the garage. put some c rap in the sttulic (had to get 2x8's to span the rafters for some storage. still have stuff to do/boxes to trash and some furniture to donate.
    I also cut the grass. Tried to figure out the edger and kept losing string in the trimmer.
    I had to have lost 5 lbs in sweat.
    On a sidenote, I will probably get an electrician to install some more outlets in the garage.
    speaking of outlets, who the he'll designed these damned tamper-resistent outlets? I don't have kids, give me the easy outlets back. I promise I won't stick a fork in the outlet.
    [​IMG][​IMG]
Share This Page
