Wheel cosmetic question?
FnSweet06
on a set of ccw wheels what would you recoment to use to clean up and polish.
Plan on buying the Mother ball today and doing some wheel cleaning.
im using this Eagle one got about 1/2 a can not sure if it'll do the job or if its enough for all 4 wheels.
JA BoostedSTANG
Jax FL
I have the mothers power ball it works good but it can sling the polish all over the place, might be pretty hard to get between your spokes as well. I would just use some good old fashion aluminum wheel polish and elbow grease every once and awhile and you should be fine.
FnSweet06
got to work yesterday and the mothers ball worked great. even inbetween the spokes. just a couple tight spots i had to get in there myself but other then that worked great. The Eagle one polish im using is more like a clay type of product so sling/splatter all over that place so thats good.
No i've heard about applying like a sealent or something to protect the wax, any recomendations?
anticubicle
1. Take the wheels off the car.
2. Soap & Water with a wheel brush. You can also use a Wheel Cleaner as long as it's clearly written that it's "Safe for All Wheels". I've used some harsh stuff on previous cars and it ate right through the clear coat!!!!
3. Not sure what wheels you have but if they're Chrome, I like to use the Turtle Wax Chrome Polish with a micro fiber cloth and elbow grease. The Powerball honestly is a piece of shit if you don't have a good drill to mount it to. Even then, like JA said — it will sling polish everywhere if you're not careful.
If they're a polished aluminum wheel with a clearcoat like the GT Premium wheels, just use soap + water and CLAYBAR them.
Natural1
all around duguder
Angleton, TX
I never actually heard you say which wheels you have (finish). If they are unfinished aluminum, then try Zoop Seal. It is expensive but once you get the polished finish you want, they will maintain that finish. I think this is what you are talking about.
Zoop Seal :thumb:
http://www.zoopseal.com/zoopseal.asp
FnSweet06
Zoop Seal :thumb:
thanks for the link. I have a set off CCW's there aluminum polish.
mykim72
los angeles
can you wax wheels? i didnt even know you could clay bar that, im going to do it next time i wash my car
