Oh, and also....
The little wire retainer clips that hold the fittings in....
BE CAREFUL not to lose them.....you can't buy just the clips, and you then have to buy the entire hose just to get the clips. I learned that lesson the hard way.
The trick is to use a small screwdriver to pop them out just enough so that you can get needle nose pliers on them to take them out. When you put them back in, put the clip in first. Then the fitting will just snap in place when you push it on.
