One thing I find interesting with the Whiteline Watts Link is how they have the Watts tower mounted to the underside of the body.
They use the two bolts at the front face of the Watts tower that are pre-existing from the OEM Panhard brace and add an additional tab, also on the front face of the Watts tower. They also use the standard cross brace that ties the driver and passenger side together but again, it also mounts on the font face of the tower.
Am I the only one who finds it strange that they are not attempting to secure the rear half of the Watts tower in some way?
I mean if they called for welding, it would make sense to not worry about the back of the tower but since they are only using bolts and all of them are on the front face it would seem that at least 50% of the Watts towers base is just flapping in the breeze, so to speak.
When you add up the weight of the tower itself along with all the components that connect to it, then you throw in the fact that the back of the tower isn't secured to the frame it begs the question as to weather or not some movement in that tower is playing any role in the types of failures seen in this thread. I mean, I would consider that tower a critical component in the chain and if it has any freedom to move then some form of Bind is sure to follow.
Has anyone welded their Whiteline unit for extra bracing purposes? If not, can anyone comment on how sturdy they feel the tower is when installed? I think a simple test would be to smack the back of the tower , open handed and see if it shows signs of lifting away from the body at the point where there are no bolts to hold it down.
