Will 11-14 fuel pump sending units/hats fit on 05-09 cars?
Suecra
Oklahoma
Pretty much the title. Seems to be lacking that information online and I would assume it does since its the same chassis but different units, because I want to run a deatschwerks fuel hat but its listed as 11-14.
Midlife Crises
Fairbanks, Alaska
The 2010 and later sending unit will not work on the 09 and earlier cars. When I installed the 07-09 GT500 dual pump setup in my 2010 I had to use the 2010 sender grafted to the new pump mount. Pain in the ass but nobody had an alternative to offer.
Suecra
Oklahoma
Are there any alternatives for 05-09? I'm having a hard time finding anything out there.
On a side note, will the 2010+ GT-500 dual fuel pump assy (including sender) work on the 2010 GT ??
Midlife Crises
Fairbanks, Alaska
My understanding is no because the 2010 is a bastard year unto itself. 2011 has a different PLC and strategy and the tank rheostat works on a different scale. The pre 2010 tank rheostat works on a different scale as well.
Suecra
Oklahoma
The wiring in my case doesnt matter i have a swapped car so im not using factory wiring, im just concerned about whether it fits, which is confusing because it should, its the same chassis.
Midlife Crises
Fairbanks, Alaska
I believe the pump hats will actually interchange but I don’t know that for sure. Do a little research and see if the 09 and 11 use the same fuel tank.
Suecra
Oklahoma
They use the same tank, thats why I was curious about fitment. I think I'll take my chances and buy an 11-14 hat because they are much more supported aftermarket and will work with my 15-17 motor better than fucking around with the trashy stock sending unit.
