half of this board still won't have a problem staying ahead.
http://www.youtube.com/watch?v=C7PJ...howthread.php?t=23195&feature=player_embedded
I would like to know what boost levels this camaro is seeing. If its in the 8-10 psi range then its pathetic, but if this gm ran that time with under 8 psi then thats scary.
If that is the case we stand no chance, only the mighty gt500s will prevail.
umm...speak for your itself - I'm not worried if they run 20 pounds of boost...
Fuck Hennessey. If he says "6-8 psi" then you can add four psi to that number. He's notorious for that shit.
Thats actually pretty impressive.Almost a 4000 lb car with 6 lbs of boost,20" tires running those times. Whether its chevy,ford or mopar
yep. ARD is doing a h/c nitrous car. It will easily see low 10's. Owen (the owner) says it will be out at 1320 in sealy to take the fastest 2010 camaro spot...at henneseys track...lmaoADR is planning on having their camaro running 10s by the next midnight 1320. I personally don't think the rear end can handle it but we'll see.
