Jim Vaccaro
- Joined
- Aug 23, 2010
- Posts
- 175
- Reaction score
- 0
I have a 185 T stat and got a check engine light.....Engine Temp Code
Car runs at 185 to 190..with cooler air now it just takes too long to heat up..I will also try letting her warm up a bit longer before driving,,,I want to keep my 185 T stat..It helps keep it cooler in summer heat..
Why would you put a hotter thermostat in? The stock one is 180.....
Someone is gonna be replacing his spark plugs sooner than expected. No reason to put a cooler T-Stat in these cars.
The tuner has now did some adjusting and cleared the code,,I think he changed the warm up time....so far so goodOh ok. Did you get the tune modified for the new thermostat?
Did he actually make adjustments, or just disable the CEL for that particular code? And what form of FI are you planning on going to.
FI--forced induction, turbo, supercharger, nitrous. That's the only reason you would need a lower temp thermostat, unless you drive in an extremely hot environment. We've only ever used the 170 degree thermostat on one 5.0 since they hit the streets last year, and that was on an 800 hp street car that was showing coolant temps in the 200's after hot lapping it at the drag strip causing it to pull timing.
By the way!!!
I called the Vendor where i bought the T stat and was told no one had reported this problem as yet!!!
Whose the vendor reicshe?
There are plenty of reasons to run a cooler thermostat in these cars as ling as the fan settings are adjusted you will are a big improvement in cooling
