2011 Owners - Miles and issues
Mystickeith50
South Jersey
2011 mt-82 bought in may of 2010...build date in march 2010.
4050 miles on it...not my dd
Zero issues....knock on wood.
jayman33
5500 miles, currently my DD but about to change. Only issue is I just got a ticket doing 105 in a 65, damn deployments always do that to me, wasnt even back for a week.
Fast351
I can't drive 55
Twin Cities, Minnesota
2011 MT82 GT
2100 miles, trans whines in 1-4 since day 1, doesn't appear to be getting worse. Shifts fine, a little hard to shift when it's colder.
LindsayEOD
2011 GT MT82
5500 miles. Its my toy only.
@4000 miles, the passenger door window motor stopped working. Replaced by dealer. Very weird but a simple fix. Other than that, no issues.
hawkeye18
omgwtfbbq
2012 GT, specifics in sig
12,500 miles
Transmission whines in every gear but 5th.
Other than that, no problems.
rmurad38
2011 Auto v6 convertible purchased Jun 2010, 9800 miles. Feet setting for Climate does not appear to be working. No drivetrain issues
ace50421
glendale
Auto with 6400 miles and the only issue was a knocking a/c compressor.
I think I may have this issue. When I start up the car I can hear a knocking sound coming out of the dash. Is this the same issue you had? This only happens when I start the car then it goes away.
ace50421
glendale
2011 5.0 MT-82 purchased Nov 2010.
8300 miles
starter wont kick off sometimes
Driver seat airbag replaced
knocking coming from vents which I havent figured out yet
front brakes squeek louder than my 1988 LX
No tranny problems to date
RazorbackMustang
MT82 Lover
Springdale, AR
8300 miles
There's a reflash TSB for the onetouch start.
2011 M6
Purchased 6/17/10
11,500 miles, no problems. Except a damn flat tire two weeks ago. FYI the 18" Pirellis cost $204 installed at the dealer. LOL
Ivan 5.0
Still learning...
NoVA
Have about 11.5K miles on it. This includes some summer road trips (two from VA to CT and back, and one VA to MI and back). Had it for a little over a year now. Car is my DD.
Only one issue so far - around 1500 miles on the odo, the car wasnt going into gear easily. Took it into the dealer and turns out the PP bolts backed out / 2 of them snapped. Dealer replaced the flywheel assembly (and associated parts), along with the tranny fluid. Problem solved.
COYO TT
Stangless
Annapolis MD
2011 M6
Purchased 6/17/10
What is one touch start?
I had this issue happen to me for the first time last week. The started kept on cranking even after I had stopped turning the key.
RazorbackMustang
MT82 Lover
Springdale, AR
You've never used it? It's great. Just turn the key to the start position and then let go, the car does the cranking and starting for you. Sometimes the starter keeps cranking because the engine didn't start, something in the tune. I've had that happen a fee times. IONO.
TimMcc
______________
Indian Land, SC
10k miles. Last 5k of that was with the whipple. Pressure plate bolts came loose at 8k.
I drive it hard.
D98GT
STREETCAR
Liberty TX
Had 16k on my 2011 (standard car) and had quite a few issues with it. It all began with pinion bearing issue at 500 miles and then again at a later date. I then had more rear end issues with the car that were frustrating. Transmission was fine at first but became very difficult to get into reverse and other gears while cold. Traded for an auto
Auto has around 3000 miles on it now and has no issues known yet.
