transmission fluid mt6
Seer
10w30??? not 5w20???
The coyote engine in other countries is actually spec'd for 5w30... we only have it spec'd for 5w20 for garbage CAFE standards in the states, and only that reason.
The TiVCT is not actuated on oil pressure like the previous 3v's variable cam timing was.
In other notes, when I had my coyote, I used Redline MTL, pretty equivelant to the Amsoil transmission fluid.
Removed the notchiness, did a lot of good. If you like Amsoil use it, its good stuff. If you like Redline use it as well, its also equally as good. I've seen enough charts and analysis to see both brands are right up there. Other brands to consider by difficult to find are Motul and Eneos, both group V oil makers who have a lot of quality products.
In before "but with the amsoil dealer discounts."
Yea, theyre decent if you buy a lot of oil in bulk or often. But with the 5000+ mile oil changes... you usually break even on it.
Atlanta GA
Last weekend (Sunday), I did another car with Amsoil MTG. We added the Steeda Tri-Ax shifter at the same time. These two mods allowed the owner of a 2012 5.0 car to slam through the gears while grinding and missing gears is a thing of the past. A bit more interior noise from the high durometer bushing in the shifter, but no added noise from the new fluid. The owners first remark about the change was, "This is how the car should have driven from the factory. Huge improvement."
Yea, I have the steeda triax and barton bracket. I'm real excited for the results and posting the results.
Nastystang06
Mt. Pleasant, Tx
I have amsoil and it will be in my transmission when the motor goes back in, I also ordered a new clutch so I may not be able to tell the difference
UnleashedBeast
Engine Lubrication Guru
Pensacola, Florida
The Boss 315 and Boss 335 take 5w-20. Try another country or produce some evidence.
That is only recent changes that were made.
You should have been reading the Aussie forums a year ago. They were all talking about how 5W-20 was near impossible to find, so they were using 30 and 40 grade lubricants just like they did in their 4.6L modular 3V and 4V engines.
It was humorous, but the smart ones on the forums didn't fall for the 5W-20 CAFE trap.
JAJ
Vancouver, BC
Someone on another forum found this link:
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=8002086&contentId=7069672
Makes it hard to argue otherwise.
That said, I was one of those people who fully expected that Ford would use a heavier oil in the supercharged Miami engine, given the evidence of the Ecoboost and GT500 engines with xw-30 and xw-50. However, even before a word was written about the oil selection, pre-launch press photos from Ford of the supercharged Boss 315/335 engines clearly showed "5w-20" on the oil cap. Hence, the recommendation has always been 5w-20.
On Australian forums after the car launched, new owners were posting "I can't believe that this watery stuff will protect my engine" and so on. Same issue, different country. I guess enough people were going off the reservation that Ford and Castrol put their foot down with the letter in the link.
Seer
See, now when I made my comment I was talking more about the 5.0 F150s, as I do believe other countries are recommending 5w30.
JAJ
Vancouver, BC
What countries other than Canada and the USA actually sell the F150's? Mexico maybe? I couldn't find any references to it in Europe, and I've never seen one there. The F-series trucks are not listed on Ford websites anywhere outside of North America that I could find, but maybe I'm not looking in the right places.
In Australia, the only cars to use the Coyote engine in any form are the FPV vehicles we've already discussed. All the trucks and utes top out with around three to four liter turbo-diesels. Only one version of the Ranger even has a gasoline engine, and it's a four liter inline six. Taxes make big displacement V8's too expensive to buy and operate for most people, so they're pretty rare.
Seer
if I am not mistaken they are exported to europe now.
302
Atlanta GA
Just swapped the fluid to mtg. Definate improvement over the stock fluid.
Rob72
No Japanese Mustang Here
Baltimore, Marxland
Just finished swapping the DCT fluid for MTG. The MTG shifts so much smoother from the get go in 35 degree weather than the DCT does after traveling a hundred plus miles in 45 degree weather. Ford should be ashamed of theirselves for recommending that garbage in their TSB.
UnleashedBeast
Pensacola, Florida
I couldn't agree with you more. Shame on you Ford!
