I'm not sure what you were trying to prove with that? But I agree, with with skinny 9" or 9.5" wide wheels and little 265s you probably
CAN run a (heavily) dimpled solid brake duct tube.
Of course your car would be faster on wider wheels and tires... which was was the point of my last post. Yes, you probably can fit some hard brake tubes in there, but at the sacrifice of wider wheels/tires, and thus a sacrifice in lap times. Yes, even with a V6 you'd be faster on wider wheels and tires. <- And that's not an opinion.
I'm not trying to prove anything or be rude. Don't take it that way. -
Our V6 Was purchased for $5,000.00 as a training tool to keep speeds down and for specific NASA TT classing – C or B. If totaled, low initial investment for a learning tool. A very easy platform to upgrade also parts are cheap and in most junk yards, fenders, doors, ECT.
The tires were purchased for dual purpose – Street, Track, Training. In a heavy car with narrower tires, lower over speed is kept with reason for training - The driver could reach the limits at a much lower speed, have fun and not reach the pucker factor. Repetition - Training their personal non-thinking and thinking motor skills in a safer / slower environment. Meaning self-automatic correction with out having to think about it for car control. With some seat time you automatically make small corrections when the car is skiterish not even thinking about it – It just happens – Much, much easier to learn when at lower speeds with an easy to read tire. I would think you might be familiar with this.
Most people don’t want to put an inexperienced driver in a heavy, 400+ HP car with wide slicks and ask them to learn the basics.
Here is a pic of the driver. Would you want you see her get hurt.? Double click on pic to expand.
Now the main subject – It doesn’t matter if you have a 225, 265 or 335 tire if the outside diameter and overall inside offset is the same. (Measurements from the inside bolting surface to the edge of the rim / tire sticking in the fender well) What this means is that only so much of the tire can be set to the inside - All the extra rubber and rim is set outward. Since only so much tire can stick in, it doesn’t matter if you have a 225, 265 or 335 tire. Both sit as far in as possible. All extra tire width is set outwardly. With the strut OD that I currently have, no more inside offset is possible. Maybe your struts are thinner. If they are, it can’t be by much. Maybe I’m wrong. If you want to get a tape measure and measure your rim / tire combo for inside offset we can compare notes. Maybe your S197 platform is different - Mine works. If you blow the pic up in my original post you can see the size of the dimple and it is oversized. Even if the dimple were bigger, the tube would out flow a ribbed, flexible tube.
