More updates and pics. Just getting all the little stuff mounted that takes time...
Radiator, coolant tank, charge pipe, trans cooler plus trying to plumb it with all new fuel lines and brake lines. I am switching to aerospace drag brakes all the way around but in the process ran into a couple issues.
First the drivers side axle won't come out. I've now removed the whole rear end assembly so I can work on that and hopefully salvage the strange axles/spool.
Second while tapping the front spindle for the aerospace caliper brackets my tap broke off in the hole. I found another set of spindles and just prepped another spindle. Not going to tap it but instead I'll get a longer bolt and run it all the way through and use a lock nut on the back side. Similar to the way racecraft spindles are done.
Also mounted my old snow meth injection kit i used to have on my red '06 then swapped out the little 5 gal. fuel cell for a 10 gal so hopefully I make the 30 mile cruise for true street events.
