GlassTop09
If anyone has 1 of these in good condition that they want to sell, hit me up.
Thanks for the link!Not sure if you are ok with non-OEM, and I cannot comment directly on quality but LMR has an Bullitt style grille
No problem. Will post pictures of the grille out of the box & post install.Let me know how the quality is! Pics look nice, especially for the price
Was curious on that aspect of the Bullitt grille too.No problem. Will post pictures of the grille out of the box & post install.
1 item I noted w\ this grille (same for the OEM original as well........this is a replica.....) is that a lot of the honeycomb on the L\R sides where the fog lights were located is blocked off so only the center section of grille is open to airflow........may not mean much as this would be following a std design pattern of the OEM Ford S197 upper grilles (fog lights would also block airflow thru the grille as well.......) but could be a future design modification (use a Dremel w\ arbor & open up these sections of blocked off honeycomb) if the need arises for more airflow thru this grille but I think this won't be necessary since this grille is also being used in tandem w\ the actual 08-09 Bullitt CAI designed to function w\ it in place.......heck, might even enhance\improve air loading (think air velocity here.....) into the "sealed" CAI housing (think improved ram air properties..........) to further improve engine available HP\TQ output at higher RPMs.......
So, I may be installing a piece primarily due to looks that may turn out to be more than this...........will definitely run some data logs post install to test for improved engine breathing at higher RPM's\improved engine cooling performance as well to then see if some more available HP\TQ output is there.
In general, yes.........but where the air entry to CAI is actually coming from (think cooler vs warmer), the approach to the CAI entrance (is it located in front of\top of the radiator core support where the air is usually denser.......) vs back side\engine side of radiator core support (where under hood heated air is more prone to mix w\ any outside air prior CAI entry due to reverse air deltaP........) & the resulting air pressure deltaP is higher (needs to be present to speed up air charge rate thus velocity) vs air pressure at CAI entry (thus the ram air effect......) will determine the final airflow potential into the engine..........THEN the rest is figuring how to effectively get it all out of the cylinders after combustion (where the exhaust has the far & away most influence on this whole aspect than the intake tract does) .......getting air in isn’t a real issue with these cars, but rather getting air out.
