BBR X-Pipe and BBR tune and you'll pick up some great numbers. Around 30hp or so. The X-Pipe made the single, largest difference in my performance. When you go F/I, the X-Pipe will still go with that setup. Then, you need to lower that puppy, put on an adjustable PHB and UCA. Finally, get your struts/shocks replaced. I couldn't believe what a HUGE difference it made with how my car handles by going with Steeda Ultralight springs and Koni STR.T dampers all around. If you're like me and want to do a little drag and auto-x, you'll also want some better wheels that can hold onto some wider shoes.
I wouldn't buy anything performance wise that will need to go once you go over to F/I. It just doesn't make sense. Headers, fuck that. You get most of the performance gains from a good 3" X-Pipe like BBR's. I would put that $1000+ into your F/I fund. The stock shorty headers are great performing factory headers.
