cobra wheels
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Two things I noticed: (1) the offsets are smaller than the S197 standard of around 45mm, which means these wheels will stick out of the fender well, and (2) to get a 17 x 10.5 on the rear might require some surgery. Even with the 27mm offset, I suspect you might have some interfence with the swaybar/bracket and possibly the shock.
J
jbailer
Guest
I have American Racing Torque Thrust-M (bullits) that are 17x10.5 rear and 17x8" front with 28mm offset. Those would be just 1mm further out than mine. Forget tucking them. They come out to maybe 1/4" past the 1/4 panel in the rear, fronts are fine.
I hadn't noticed any issues with the wheel. The S197 in 05+06 at least came with the 17" wheel, the 18" wheel was an upgrade. Don, the wheel sticks out further rather than more offset that would make it come in closer to the swaybar bracket and such. I can check more on mine if you tell me what to look for. -Joe
don_w
San Diego, CA
... see if M&H is ever coming out with their 325/whatever/18's...
An existing option for drag radials to fit an 18x10 wheel is the Nitto 555R. They come in 305/40-18 (27.7" dia) and a 305/45-18 (28.8" dia).
Liftedbronco
Shredder
Harrington Park, NJ
yes that is true too. hm, id better go order them then!
my belt issue is over, so with some traction and some ice in my intercooler i should see 11's if nothing breaks this time.
