2011+ power adder registry
Trousersnake
I've been looking around, a lot of us know one another but I was thinking there should be a list for guys thinking about joining the club.
Year:
Trans:
Power adder:
Rear gear:
Other mods:
Wheel tire combo:
Tuner:
Dyno #'s :
Et/mph:
This should get the ball rolling in a easy format.. On svtperformance there is one but there's a da Vinci code on figuring it out.
DSargent09
Get iT!
I wish this would have got going. I would love to get feedback here from other people on their kits and things.
I will have a Paxton on mine by the end of this month.
Trousersnake
People got scared... I ordered a Paxton set up also.. Ill post up once its on
DTony
Ohio
I will jump in.
Year: 2011
Trans: Auto with Circle D 3c converter
Power adder: Vortech V3Si 12 lbs of boost
Rear gear: 3:31
Other mods: Long tubes, Boss intake, Boss short block
Wheel tire combo: Race Star 94's 17 by 7 fronts with Cooper radials, 15 by 10 rears with MT pro 275 dr's
Tuner: Jeff Chambers at CRT Performance
Dyno #'s : 688/520 on a Mustang dyno and pump gas
Et/mph:Best et 9.89 best mph 140.8
larry03gt
Abilene TX
Year: 2012
Trans: M6
Power adder: Roush 2300 TVS 7# boost
Rear gear: 373
Other mods: JLT big air CAI, Magnaflow off road X
Wheel tire combo: Stock Brembo pak wheels & tires
Tuner: Jon Lund
Dyno #'s : 554/497
Et/mph: N/A
mr. anderson
Moore, OK
Year: 2011
Trans: M6 stock
Power adder: Kenne Bell 2.8 LC (12-13 pounds, 3.5" upper, stock lower)
Rear gear: 3.73's (stock)
Other mods: KB 168mm throttle body, 75# flow matched injectors, KB 40A BAP, BBK 1 3/4" ceramic coated LT's, BBK 3" ORX, Corsa extreme axleback, Mcleod RXT twin disk & billet steel flywheel, MGW shifter, J&M LCA's, Koni Yellow's, FRPP "P" springs, UPR adj panhard bar, FRPP rear end girdle, poly motor mounts
Wheel tire combo: Forgestar F: 19x9(245/45's) R: 19x11's(Nitto invo 305/30's) Drag wheel: Weld RT-S 15x10's M/T ET drag radials 295/55 15's
Tuner: Lund Racing- SCT
Dyno #'s : datalogging in work
Et/mph: No blower runs yet
JDM74
Suffolk, Va
Year: 2011
Trans: M6
Power adder: FRPP 525 Whipple Kit
Rear gear: 3.55
Other mods: JLT Big Air CAI
Wheel tire combo: Forgestar F16's 19x9/19x10 255/285 Nitto Envos
Tuner: Brent @ Dyno Tuned Performance
Dyno #'s : 522 Hp/415 Tq
Et/mph: NA
Juiced 66
Lake Jackson (Houston)
Year 2011
Trans Stick shift baby !
Power adder Paxton novi 2200 3.6 pulley with JLT intake
Rear gear 3:73
Other mods Boss intake,BBK long tubes,offroad X,Magnaflow cat back,ID1000's,KB BAP,aluminum driveshaft,eibach springs,panhard bar,Barton shifter bracket
Wheel/tire combo AM wheels stock front tires, MT 315 drag radials out back
Tuner Jim from JDM Engineering..
Dyno #'s 759/593 with 3.3 pulley on pump gas in 20* air
(Swapped back to 3.6 but haven't been on the dyno with it yet)
ET. 10.96@127 back when I had N2O.. No numbers yet with blower
DSargent09
Get iT!
Year 2011
Rear gear 3:73
Built motor....?
