4.56's and spray?
TurboPete
Miami, Fl
yes i bogged with 28s and 4.10s i dont bog with 26s and 4.10s. I have a stock long block with cams and shift at 6200. I dump the clutch at 6500 rpms i dont shift at that. 1.5s is my 60fts all day long.
Wow Ok , well are you dead hooking or spinning a little on the hit?
Did you try raising the shot with the 28s , you can spray with a 4.30s but you need the 28s . It will leave better .
Pete
Lil Hucky
4.30's with the 28's should be a good combo for you. I have 3.73's with a 27" tire, but cannot leave the line over 5000 rpm or I spin, any less it bogs. (However I'm not sparying out of the hole each and everytime.) You're cutting some pretty sick 60's and as long as you're dead hooking step up to the 4.30's with the 28's - Pete's right it will leave better with more gear.
JP229
Washington, MO
What kinda of MPH will a 4.30 and a 26" tall tire allowed compared to with a 28" tall tire?
OP, what clutch are you running??
