Synyster06Gates
Not my photo - but dealing with something similar. I know epoxy would work, but I feel like it would get all over the place. Any ideas on how to seal something like this up and not look too bad?
Synyster06Gates,
No experience with this sort of repair but here is what I would do if faced with something like this. No offense taken if you don't like my advice (it's free ).
How about 'injecting' some clear RTV into the crack by using the little plastic nozzle cut at the first slant? I'd tape off both sides and as soon as the injection is done, with the area down to remove any excess. You might experiment on another piece of plastic first and, as a second test, try Crazy Glue. That stuff is miserable if overspread so I don't know now you would get it into the crack. Maybe a syringe (if you can find one)? If the crack goes through, you should work from the back side but still have the exposed side taped to prevent any goop from spreading.
3M makes a red plastic (temporary) plastic 'taillight repair kit'. Not sure how long it would last but 3M makes some good stuff, lol.
Option 3 is to try clear coat. You can buy a little touch-up bottle with the brush and pen tip and poke it into the crack. Should do the trick.
HTH,
Chris
Considered it - but doesn't superglue eat away at plastic?I would just get some super glue and put a thin bead over the crack.
Why not just replace the entire tail light? They are cheap enough these days. I replaced my headlights just because they had a few rock chips and swirly scratches in them. Didn't matter how much I waxed those suckers, they scratch terribly easy. I admit I stole a pair off ebay for $45 shipped. However, even $100 is worth keeping that "like new" look.
Are 13- 14 taillights prone to cracking like this?
No, the ones on ebay are from wrecked cars.
