Dubstep Shep
WUB WUB VROOM VROOM
With my move to the RR-Spec I have a need for a serious heat exchanger. I'm removing the A/C and moving the bumper a little further out. That should provide me enough real estate to get something gigantic up there.
Obviously there are no bolt on HEs for my application, but I had some questions about a custom one...
Basically I was thinking about grabbing a few OEM radiators and stripping off the plastic sides, then having custom sides welded on to make a two or three core thick HE. It would certainly be a bit cheaper, and the dimensions would be pretty darn close to perfect. Not sure if I should run the cores in series or parallel, but that's going to depend on what pump setup I end up going with.
Thoughts?
Thoughts?
