Since quite a few forum members (including me) bought a set of shiny new Racestars from Beefcake, I figured this might be a helpful thread. I've never owned dedicated drag wheels before, and I'm still a little up in the air on what tires I should run.
I bought 17x4.5" fronts, and 17x10s out back. I'll probably change my wheels at home, and drive to/from the track on my race wheels. My car is lowered 1" in front and 1.25" in back with Steeda Ultralite Springs and Koni STR.T shocks/struts.
The selection of tires for the front is pretty straightforward, I plan on using the 185/55/17 M&H Racemasters.
However, the backs are more complicated. I'm not sure whether I should use drag radials or bias ply slicks. I want to run a 27-28" tall tire out back because I have 3.73 gears and with my 27" tall Brembo wheels, the car is right around the limiter as I run through the traps at 110 mph. I want avoid having to shift into 5th while still running the stock tune/limiter.
M&H makes a 325/45/17, which is about 28.5" tall. Would these even fit on a 10" rim, and inside the fenderwell? Anyone have any experience with them?
http://www.americanmuscle.com/mh-radial-325-45-17.html
Hoosier makes a 28x10x17 bias ply slick that looks like it would work.
http://www.summitracing.com/parts/hoo-18157/overview/
The Mickey Thompson ET Street Radial II comes in 295/24/17, which is about 27.5" tall and would work.
http://www.americanmuscle.com/mickey-thompson-street-radial-295r17.html
I could use some advice or experience with any of these tires, or another one I've not mentioned.
Paul.
Paul.
