Hollowdweller
- Joined
- Jul 10, 2018
- Posts
- 328
- Reaction score
- 37
I’m wanting to replace the brake line from the brake booster to the proportioning valve (think that’s what it’s called) but don’t know the size…? I’m adding line lock. Wanting to make a custom line from the booster to the solenoid, then from solenoid to prop valve. Can I use the same style fitting on both ends of the line? In other words, will the fittings that screw into the booster & valve also screw into the solenoid?
