Datalogging knock...virtual dyno.
GOTTORQ
Connecticut
today for the first time i downloaded live link to play with it and check it out. i was trying to see if i had any counts of knock throughout my logs. But all i could find was knock volts, among other options involving other types of knock. I searched it and found other members have asked the same question and havent found and answer.
I also tried a program called virtual dyno, which is pretty accurate it seems. I did a 3rd gear pull from 2k-6300k, i logged time, throttle position, RPM, and vehicle speed. Saved the log in microsoft excel. Downloaded virtual dyno, inserted my data log. the program takes in for vehicle weight, tire size, air temp, how much weight was in the car, final drive, and what gear you were in. you can also choose what dyno you would like, dynojet, mustang dyno, or virutal dyno which is a mixture of the two. car made 319whp according to the program. seems accurate for my mods.
I'm trying to do this with a data log from my Predator. Do you guys have any idea what throttle position might be labeled as?
