EagleStroker
N/A Junkie
Need some help to not go insane on this issue. I nearly sold the car because of 'one more problem.'
The car was an every day driver for a few months while I overhauled my truck, and then it sat for about two months. When I went back to drive it I felt a slight vibration. I assumed it was a slight flat spot and went on driving. After about 100-150 miles the vibration increased considerably, to the point the car isn't safe to drive. It comes in about 20 mph and gets increasingly violent shaking the entire car. It does not change with accel/decel, left/right, clutch in or out. No difference with another set of wheels and tires, either.
My impression is it is behind the transmission. First thought was a u joint but they are not whining and have little to no play in them. The driveshaft is a dynotech 1 pc and has only had a couple thousand miles on it. I'm frankly stumped and fed up with problems.
The car sat for another few months as I just had to walk away. We have good weather this weekend so I'm going to do some maintenance and give things another look. Suggestions/questions are what I need, I just need a starting point.
