GriffX
I'm looking to minimize the NVH at the Ford 2-piece driveshaft support bearing.
Does someone measured the U-joint angle to the shaft?
I got 2.7 to 2.8 degree, which for me is at the upper limit of 3 degree. The value of a one piece driveshaft is also interesting.
I have a very loud sharp resonance at 65-69 mph.
How can I lower this angle to 1.5 to 2.0 degree? There is an aluminum spacer, but don't know if I can just remove it or must add a thinner one, at least a washer. 0 degree would be ideal for vibrations.
This rubber looks like a circular bump stop, not like all other support bearings from other car brands I have seen so far.
