*JZ*
Autolite HT0 - set of 8
These are a Perfect Upgrade For your Power Adder - 1 degree Colder Plug.
NEW!! Autolite Revolution HT Spark Plugs
Unique High Thread Design for:
More Power:
*Superior Cylinder Head Seating Postion
*Better Compressive Seal
*Improved Heat Transfer
*More Focused Ignition
More Durability:
*Longer Service Life
*Improved Corrosion Protection
*No Manual Gap Nessary
*Requires 9/16 in. Socket Wrench
Part #: HT0-8
Regular price: $89.99
On Sale: $72.00
BBR 2005-2009 Mustang Trunk Release Kit
Blow-By Racing is proud to bring you what Ford forgot. We addressed the issue of not having a trunk release button. As most of you know the 2005-2009 mustangs are the only years without a trunk release button... until now.
We have the answer; our complete plug and play kit is an easy 30 minute install. Our kit comes with a pre-wired button, wires cut to length, and everything you need.
Our kit simply mounts in your center console above the power point in the factory access panel.
Note: picture show switch installed in panel.
Part #: BBR-0507-015
Regular price: $49.99
On Sale: $24.95
TA Performance 8.8 Rear End Girdle - Ultra Low
Specifically designed to add support to the bearing caps under severe loads and acceleration, these girdles substantially strengthen the rear end. They also add fluid capacity, which helps to lower the fluid temperature. Comes with drain and fill plugs for easy maintenance.
* All TA Girdles are made of 356 aircraft grade aluminum, heat treated to T6 specifications, each cover is then stress relieved.
* All Girdles incorporate a Fill Port and a Drain Port for ease of servicing.
* All Girdles incorporate 2 load bolts with swivel "feet" for supporting the bearing caps.
* All Girdles increase fluid capacity approx. 1/2 pint.
* All Girdles show a decrease in operating temperature, average of 15 degrees.
* Weighs about 7.5 lbs.
* Improves Undercarriage Appearance.
We machine all of our girdles in house to insure the highest quality possible. Each cover is machined using a 3 step CNC process which insures accuracy and high quality. Then each cover is hand deburred and inspected for the utmost in fit and finish. each cover is hand assembled and packaged.
Part #: TA-1806B
Regular price: $189.95
On Sale: $147.95
Plus MUCH MUCH MORE ! ! ! !
Check out our website for more sales!!!!!!!!
www.BlowByRacing.com
