First time purchasing a Porter Cable?
06TORCHEDGT
South Carolina
I think Im gonna pull the trigger and buy a porter cable DA as im tired off looking at fine swirls in my paint on my 06 and my 99 needs a really good compounding. I thought about having a professional do the cars for me but just for one car im looking around 300+ bucks. I was looking on autogeek but I have no idea where to start...they have so many different kits on there! Ive heard good things about the meguiars 105 and 205 products but just a complete newb when it comes down to buying the polisher and pads.
Bill220
If you have the money, skip the PC and buy a Flex. It's a much nicer machine.
3VPOWA
East Texas
So is the Porter-Cable just not as good anymore? Or is it just not as functional when compared to the Flex? It was touted as the best for several years, and they look to be cheaper than the past. Only $113 on Amazon.
Bill220
I have a PC XP and it works just fine. I got to use a friend's Flex and it worked faster and was a lot more comfortable to use.
Seer
Thank you sir.
Theyre both more expensive, but theyre both a lot better than the PC.
Don't get me wrong, the PC is more than adequate for a hobbyist or someone who only intends to polish their car once or twice a year. But it does take a good bit longer to accomplish the task and doesnt have the level of correction or throw as the Flex or Rupes.
Flex 3401 Forced Rotation DA
https://www.autoality.com/store/pc/viewPrd.asp?idproduct=6256&idcategory=0
Rupes LHR21ES
http://www.rupestool.com/p/us/en/0262777815359
The new Rupes Bigfoot, is considered a next generation polisher, I consider it having a slight advantage on the Flex 3401, after using it for the past few months.
Rasmus
It's not that the PC is bad. The Flex is just better through and through. Well worth the extra money.
I've tried the Bigfoot a couple of times, but I still prefer the Flex. I may have to give it more tries before it wins me over, but for now I'll stick with the Flex.
Seer
It takes people a little while to convert to the Bigfoot, it is a different school of thought.
3VPOWA
East Texas
So like Seer said above, would it be worth dropping the money for the Flex if I only intend to detail the car once or twice a year? I'm not planning to go all out. Just want to get all of the swirls out and lay down a nice layer of sealant and wax to protect the paint for awhile.
Rasmus
Let's say you have a big back yard.
This is one:
This is the other:
The one to get is up to you. I will promise, though, that you'll end up using it more than you think.
28ONE
The City
I started with PC but then went to the Flex, night and day difference. Using the Flex definitely speeds things up. Can't use 3 inch pads with my Flex3401 though, something I miss when using the PC.
As for your intentions, PC will do just fine. It may take 3 to 4 passes on that black paint. That was my experience. Keep in mind the cost for backing plates, considerable difference between the two...
Seer
I said the.flex will do the job faster and more effectively. Its up to you if you perceieve the value in that statement.
3VPOWA
East Texas
All good info. Definitely going to look into the Flex, then.
And Rasmus, I would use this:
Djstorm100
My problem is when it know which products to use. Like compounds polishes and etc.
