Ford Racing 5.0L Crate Engine, Available Starting Aug 15, 2010!!
Harrisburg, PA
From CJ's Blog..
You have been patient, you have waited eagerly, and now the very popular 5.0-liter crate engine from Ford Racing is less than two weeks away from being available to all you horsepower hungry Ford fans! CJ Pony Parts has the scoop on the new crate engine available from Ford Racing, and is ready to start taking pre-orders, today!
At the beginning of the summer, we all fell in love with the 2011 5.0L Mustang. An iconic car, paired with an updated version of its favorite engine, was all any Ford fan could talk about. Then we started asking, “When can I make MY Mustang a 5.0?!”
In short order, Ford Racing announced that near the end of the summer, they would have a 5.0-liter crate engine available to drop into your vehicle of choice. Today, Ford Racing has announced that the 5.0 engine will be available on August 15th, 2010. CJ Pony Parts already has the crate engine (Ford part #: M-6007-M50) on our website available for pre-order. We are proud to announce that it will also qualify for our Free Shipping policy!
Info and specifications from Ford Racing’s website:
Ford Racing’s new all-aluminum 5.0L Mustang crate engine is a modern 5.0L 32-valve DOHC V-8 that uses advanced features like Twin Independent Variable Camshaft Timing (Ti-VCT) to deliver 412+ horsepower @ 6500 rpm and 390 ft.-lb.+ of torque @ 4250 rpm (with premium fuel).
-11.0:1 compression ratio
-Lightweight aluminum cylinder block with cross-bolted main bearing caps and thick main bearing bulkheads for bottom-end strength
-Piston-cooling jets, optimized oil drainback and windage control to improve high-rpm performance
-Deep sump oil pan with 8qt capacity
-Tuned composite intake manifold, providing efficient air delivery and weight savings
-80mm single bore “drive-by-wire” throttle body
-Four-valve-per-cylinder aluminum heads with roller-finger followers to reduce friction
-Includes manual transmission engine harness and flywheel
-Vehicle harness and PCM not included
-Use Ford Racing’s NEW wiring, PCM and installation kit (M-6017-A504V) designed for street rod/project car installation.
-Does not include alternator, for alternator kit see Ford Racing’s (M-8600-M50ALT)
-Engine mount bosses and bellhousing mount pattern common to 4.6L modular engines.
-Direct replacement for 2011 Mustangs with engine code BG-397-AA
-Engine weight: 444 lbs
Head over to www.cjponyparts.com and get yours on order today. We cannot wait to see what vehicles our customers plan to put this new crate engine into! If you are looking for inspiration, head over to stangnet.com and check out their “Built to Cruise” project.
