Selling my Stage 3 Killer Chiller. This is a complete Cabin cooling Bypass. All of the A/C power goes to colling the intercooler fluid. It can be converted to a stage 2 kit by changing one fitting which you can get from Joe at Killer Chiller for a few bucks. I am including:
Killer Chiller unit
Coolant temp gauge
all of the fittings
some brand new Neoprene to insulate your coolant tank to keep the fluid as cold as possible
all of the A/C hoses
Instructions - here
**You may or may not need more of the hose depending on how you run the lines in your car.
For those concerned with condensation and dripping, ect. I never saw condensation on the lines nor did I drip anything on the track. Not even on a 90 degree day.
asking 600 obo, retail is 799.99
From Lethal Performance's Site:
For drag racing most of our customers turn the system on during the return from the end of the track, and then off just before staging again. This has allowed our customers to spend their time at the track "racing", instead of icing 45 minutes in-between runs..
System comes with all necessary
lines hoses fittings & retainers
comes with your choice of red,
blue or green led temp gauge for monitoring IC temperatures
Guaranteed to lower your
IC temp 50 to 55 degrees
Starting at: $799.00
Killer Chiller unit
Coolant temp gauge
all of the fittings
Instructions - here
