Matt.S@Lethal
- Joined
- Jul 5, 2012
- Posts
- 50
- Reaction score
- 0
Before saying farewell to our beloved 2010 Shelby GT500 (still for sale!), we decided she could use some love in the form of a full exterior detail. The car only has less than 3,000 miles, but has never received a proper detail including full paint correction. The paint definitely needed some help to say the least. As with any car that’s a few year’s old and never been fully detailed, it had some swirl marks that needed to be addressed along with some water spotting and oxidation.
The first step is to get the vehicle clean, and I decided to start with the wheels and tires. To get the wheels cleaned up, I opted for some Sonax Full Effect with a Daytona Speedmaster Wheel Brush.
You can literally see this wheel cleaner working - as it bonds to iron brake dust particles, it dissolves them into a reddish purple emulsion. Best of all, this cleaner is completely non-acidic and will not harm wheels with regular use.
As you can see, the Daytona Speedmaster Wheel Brush is extremely flexible and effective not only for cleaning between spokes, but also inside the wheel barrels, behind spokes, and even the brake calipers and wheel wells.
To clean the remaining areas, I opted for one of our All Purpose microfiber towels - they are very cheap and effective for cleaning tires and wheel faces. If you use these for this purpose, be sure to use separate towels on the tires and wheels to prevent cross-contamination.
Now that the wheels and tires are sparkling clean, it’s time to address the rest of the vehicle. I decided to use Meguiar’s Gold Class Shampoo with a couple of our microfiber Zero Cuff wash mitts.
Gold Class loosened any dirt, grime, and warehouse dust that was present on the finish, allowing everything to be rinsed clean.
Once the vehicle was completely clean, I used a couple of our Waffle Weave drying towels to get it dry.
While the paint was still in the sun, I decided to snap a few shots to show its condition.
I used a simple sandwich bag test to assess the finish. To do this, place your hand in a sandwich baggie and run it over a clean area of paint. The bag will allow you to feel every bump and imperfection on the paint surface. If your paint feels like sandpaper, you probably need to use clay. And to say the least, the Shelby definitely needed it.
For the claying step, I decided to go with Griot’s Garage Paint Cleaning Clay with Pinnacle Clay Lubricant. This medium grade clay is fairly easy to work with - it’s pliable and does a pretty good job of removing embedded contaminants without being harsh to paintwork.
Upon opening the Griot’s clay, this is what you’ll see.
