levelbelow2000
- Joined
- Jul 8, 2010
- Posts
- 404
- Reaction score
- 0
I just installed the Shaftmaster 3.5 aluminum driveshaft in my 2011 5.0. My cars a 6-speed manual car. The install went very easy, everything was good till I drove it. I left my shop and felt a slight vibration, then when I got on the highway, 70-80mph, the vibration is terrible, sounds and feels like when u ride over the rumble strips on the highway. It dont do it when your on the throttle but as soon as u let off the throttle the vibration is there.
So I get off the highway and go back to shop. I put it on a frame machine (flat lift), so the suspension was loaded. I checked to see if it was rubbing on anything and it wasnt. So I thought I might have to index the driveshaft, so I marked it and rotated it on the pinon flange one bolt hole to the left. Then I drove, seemed to get better. I did this 4times till the vibration seemed to go away. But it came back on the ride home.
My car is lowered and I dont have a adjustable upper control arm, so I thought maybe the vibration was because my pinon angle was off. So when I got home I put my stock springs back in it and drove it. Same vibration, I cant get rid of it. I have 2 more holes to rotate it on the pinon flange but if this dont work I dont know what else to try. Any suggestions? Anybody have a similar problem?
