longer wheel studs
duece05
what is involved in installing longer wheel studs in the rear axles. does the third member cover have to be removed. what id the proceedure to bull the rear axles. Mechanically inclined, but just have never removed axles from a car.
thump_rrr
Montreal Qc,
All you need is a BFH (not to be confused with your BFF Jill), new studs, an impact gun, a few grade 10.8 1/2" x 20 nuts, and a stack of washers.
Smack out the old and pull in the new.
duece05
Don't I have to remove the axles to remove the old studes, or is there a hole behind the axle flange for them to go through?
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
the ole phrase " happily retarded " comes to mind lmao , if i remember correctly you remove the caliper , caliper bracket , then rotors and beat them out with thumps bff slide the new ones through add a few washers pull it through , add more pull more ect. until tight
