ModifyMyStang.com
Vendor
- Joined
- Mar 10, 2009
- Posts
- 4,603
- Reaction score
- 1
The Metco Motorsports fuel rail kit for the new Mustang includes rails precision machined from billet aluminum, not commonly available extruded rail stock like other fuel rail kits.
Because our rails are CNC-machined from billet, we were able to design them with the largest internal diameter available for this application at 11/16". The kit includes a custom-made braided stainless steel fuel crossover line with swivel fittings, a port plug for the front of the passenger side rail, and a #8 AN adapter for the front of the driver's side rail. These rails can be used with the factory returnless fuel system or with a custom return-style fuel system.
Two 1/8" NPT ports are located at the front of the passenger side rail to facillitate the installation of a fuel pressure gauge, to provide a fuel supply for a nitrous system, or both. Pipe plugs are included to seal any unused ports.
The rails are clear-anodized for long lasting surface protection, and precision-bent stainless steel mounting brackets and stainless fasteners are included to attach the rails to the OEM mounting brackets.
A special adapter (Metco Motorsports PN MFF0008, also listed in this section) is available separately to mate the front of the driver's side fuel rail to the factory fuel feed line. This adapter is necessary to use the Metco Motorsports fuel rails with the original fuel feed line.
Note: These fuel rails are also available in a high-polished finish under Metco Motorsports PN MFR2005P, also listed in this section.
http://metcomotorsports.com/proddetail.asp?prod=MFR2005A&cat=102
Post up if intrested~
