First off I understand I have a 3.7 and not a 5.0. But the 3.7 section seems a bit dead.
Well over the past two weeks I started developing a 6th gear grind when my transmission was cold. it was not bad. just a quietish almost chirp if you will of a grinding noise. Well this grinding noise had gotten worse and my 5th gear also started to make grinding noises that were moderately bad.
I took my car to the dealership and had my transmission flushed, which according to ford should help things. Well it did for 5th gear, and partially for 6th gear. The only issue now is on a less frequent basis now I have a significantly louder grinding noise when I try to put my car in gear. I am also now having issues going in to 6th gear when this happens, and its not just when the tranny is cold.
Is this a sign that my 6th gear syncro is going bad? Or what could be the possible causes of my issues.
TL
R MT82 sucks
TL
