Androdz
Banned
the 5.4 3v has a forged crank from the factory? how hard is it to put in any real modifications? I have a busted 5.4 3v in my garage right now.
Andrew
Andrew
Andrew
Yes the 5.4 has a forged crank, but it still has the same rod/piston make up as the 4.6 n/a motors.
The 5.4 has some interesting issues, Ford uses pretty much the same piston in the 4.6 as the 5.4, which puts the piston about .120 in the hole (below the deck), so custom pistons are a must as most off the shelf stuff is the same as Fords design.
The 5.4 will pretty much drop right in, The 4.6 mounts are not going to work, the block is just a touch wider (you could use Gt500 mounts). The big problem is intake and exhaust manifolds. 4.6 3v manifolds can be made to work, but will require a bit of exhaust work. Intakes are nil, There is nothing that will work well, especially in n/a form.
We have done this swap for one customer, Here is a link, http://www.rygen.net/stang/54stage1.html
hmm thanks alot!! All being said and done was it worth it? who made the pistons? What would a set run me into think you could sell me a pair since you already did one lol.
Andrew
Mike,
What class are you planning to run?
SD , I don't have any class.........
