Well I have finally decided it is time for a new block with forged internals. The car is somewhat of a daily driver & sees the track on occasion. As my signature says, I am running a Procharger & want to inrease the boost safely. I have been following various threads on blocks, heads & cams but I still have questions. At this point, I am not looking to go into the 700+ RWHP probably somewhere between 5-600.
1. I am considering a short block built by Livernois, DSS, or Larry H (I will send you a PM). Anybody have any experience with these builders & can provide some pros & cons or some other suggestions?
2. I was originally going to include P & P heads but after reading that the factory heads are good for 800 HP, I think it would be spending on something I don't require since I am not planning on going near that much power. True or false?
3. I also want to do Comp stage 3 cams with upgraded valve springs & retainers. Good addition or not?
When I pull the engine, I am also planning to replace the flywheel, clutch, pilot bearing & slave cylinder. Since many of you have been through this process before (and sometimes twice - Chevy Killer!) any other advice on things I may be missing, overlooking etc. would be greatly appreciated.
