New from Canada
Dreax
Northern Alberta, Canada
Thanks. I've looked through quite a few threads already but I didn't see quite what I'm looking for. I want to put a coyote and a 6 speed tremec into a 2005 v6 with an automatic. Seems like all of the coyote swaps are replacing the 4.6, I'm wondering how much extra work it's going to be to replace the v6
obsrt86
Hello from Canada! I found this forum and thought I could get some advice on doing an engine swap.
Welcome aboard! There's a ton of info on swaps on here. Good luck with your build.
TGR96
el blanco nino
Huntsville, AL
Welcome!
If you follow through with the engine swap, you should do a thread on here covering it.
