It's always best to wait until the machine shop tells you what will be needed.
This is the best thing to do IMO.
I think that I have this sorted out:
(1) the oil squirters are gone - cost savings most likely
(2) pistons are not like M&M's they are heat treated
(3) #8 is still a puzzle (appears to run hotter than the rest - header design?)
(4) small improvements to an exisiting design <> a redesign
(5) oil consumption is an unknown
IMO, cost savings is not what it was done for.
Then what was it done for?
Oil squirters cool pistons, so removing them certainly wouldn't help the "#8 Issue."
We don't know. Only an official answer from someone at Ford will be able to answer that. Piston squirters aren't a huge expense. New pistons and a newly designed block are a huge expense. The new block alone is a few hundred dollars more than the old one. There has to be more to the change. More than cost, Ford is focused on durability. This IMO, is a durability change. And possibly, not even because of the Mustang. It's possible, there are durability issues in the F-150's where this engine is really put under a load for long periods of time. If there's a possible #8 issue in a mustang that weighs 3600lbs and runs wide open for 12 seconds, imagine what it's doing in a 7000lb truck run wide open when towing for minutes at a time.Then what was it done for?
Solution:
Install SC of your choice (limit boost to < 10 psig, RPM <7000), add some long tubes to protect #8 and reduce oil consumption at the same time. Maybe add a bigger radiator and an oil cooler.
What do you guys think about the above advice? Yes, no, make no diff?
I agree with the above after reading this...
http://www.mustang50magazine.com/te...ord_mustang_gt_50_coyote_engine/photo_56.html
