Oh Boy..exhaust trumpeting?
teeje
Ohio
My mustang is FBO and this has been something ive been trying to tackle even when I was stock with cat deletes. But ill be waiting for your video. Im interesting in seeing if its the same.
MrAwesome987
Upstate SC
Here's two clips of my car. First video is in 3rd gear, and the second video is in 4th gear. Ignore the break squealing in the first video...
teeje
Ohio
I hear it. It's sounds more mettalic, kind of like a tick-ish noise inside the cabin
07gts197
Naples, Fl
It sounds normal to me. These cars like to trumpet, I dont think theres really a way around it unless you have factory cats.
teeje
Ohio
Im going to put some fr500s in the back, see if that helps.
MrAwesome987
Upstate SC
I'll probably try a new axle back down the road, but right now it's not hurting performance, so I'd rather throw money at go fast parts lol
teeje
Ohio
Got the super 10s in and it sounds meaty. Super deep idle and 99% of the trumpeting is gone.
Riptide
Will work for Mustang.
Montucky
I went through a couple exhausts and returned them to amazon for a full refund. The gt500 axle backs went back in. The outlaws were too raspy and blatty sounding. The stingers were raspy too, and I could never get the tips to stay lined up.
teeje
Ohio
Well the sound is still there. I believe it’s something to do with the x pipe. Im going to try a prochamber. Wish me luck
eighty6gt
I just spent $1100 on JBA longtubes and an H pipe
another 250 on M80's
THIS BETTER CURE IT BY GOD OR I'M BURNING THE CAR
I have the identical setup JBA's ( titanium ceramic coated ) JBA H pipe... and a pair of welded in M80's. At the time, the M80's from AM were $44.00 each. Flanges on each end of the M80's cut off in band saw.... then they were welded in.... just b4 the rear axle.
No need to burn the car. But they need to heat cycle several times .....so fully evaluate em after 2-3-4 weeks. After that, they won't change.
Also bought new oem Ford header gaskets. Came as a pair, also from AM...dirt cheap at the time. FRPP gaskets. Don't re-use the old crap. LT's are a tedious enough install. Check TQ on header bolts after a month..then 1-2 per year after.
eighty6gt
M80's only $52/ea
Exchange, shipping, duty, taxes
$260 for two in Saskatchewan!!
