GTJohn, If I read your post correctly, you have the pass. side open to the air and the Driver's side still plumbed to the intake behind the TB?
If so, you are potentially drawing in unmetered air through the crank-case which will cause you to run a little lean.
It would be better to bypass both sides than one - the system either needs to be closed or not connected at all.
My car has been tuned for this change.
I appreciate the info John, but there's one thing about your setup that bugs me... The PCV circuit NEEDS to be a closed loop, after the MAF. With your setup, whenever the PCV valve is open, drawing air through the separator, the source for that air is through the breather on your passenger side, which is now admitting UNMETERED air into the engine. This will cause you to run lean, since as far as the engine is concerned, it's a vacuum leak. I'm pretty sure that you want EITHER a complete closed loop (with the separator, and with the passenger-side hose connected to the CAI ducting after the MAF) or you want a completely open loop, with breathers (local or remote) on both sides, and with the PCV port plugged.
I think if you set it up all three ways (closed loop, open loop, hybrid like you're running now) and datalog the LTFT and STFT, you'll see the computer commanding rich...
The LTFT has also been disabled and no longer influence the STFT.
Been running this way for almost 2 years. My daily N/A driver just the way I drive it to work everyday runs 13.5 sec in a 1/4 mile at 102mph.
The ram air system I have installed probably helps.......a little.
As stated before the stock passenger side hose running to the intake just after the MAFS is for environmental protection and thats all.
Not trying to be argumentive guys.
