P0171, P0174, & P0340
ZwookY
05 GT and I recently received these codes, P0171, P0174, P0340
Anyone know a specific reason that would trigger theses 3 codes together?
MAF maybe? IS the cam sensor totally unrelated?
Car runs but gets a little sluggish here and there for a couple seconds.
When I clear the codes, car runs fine.
This is the second or 3rd time in the last 2 years I've gotten these codes.
StockishS197
Houston
Any time P0340 pops up, the alternator could be suspect. What is your battery voltage while running?
Low voltage or a failing diode causing AC ripple wreaks havoc on these cars.
ZwookY
You’re right on. My brand new alternator that was replaced on Memorial Day failed the diode portion of the test.
Got a replacement but unfortunately it’s pouring rain.
StockishS197
Houston
Keep an eye out on the replacement.
Most parts stores alts are reman and will fail again within a few years. I have found that the “new” more expensive ones do last longer, but the lifetime warranty for these more expensive units pays for itself on these cars
ZwookY
2nd new alternator passed both tests and everything seems fine, no codes in the little bit I've driven it so far.
I had to drive a few times yesterday before fixing and the codes appeared just minutes into each drive.
I "think" I'm good now. :)
