P0308, Bad Compression
Discussion in '2011+ Mustang GT 5.0L Tech' started by brendan127, Aug 31, 2018.
  1. brendan127
    brendan127 Junior Member
    It has 25psi compression, and 99% leak down on #8.
    So what is needed to fix the car when it drops #8? I was quoted $9800 from brenspeed to fix it and I'm not interested in going that route, because I want to trade the car in at some point.
    Is it able to be fixed by just replacing the rings, and maybe the piston? If the cylinder wall is bad couldn't that just be sleeved?
  2. stkjock
    stkjock ---- Madmin ---- Staff Member S197 Team Member
    36,925
    441
    motor needs to come out and be rebuilt
    if you can do a swap, finding a junkyard motor would be least costly way
  3. weather man
    weather man Persistance Is A Bitch S197 Team Member
    13,140
    22
    Fleabay motor swap be cheapest.
  4. brendan127
    But why? What's keeping it from just being able to change the rings? Because it runs fine aside from pouring smoke out.
  5. brendan127
    A junkyard motor is still 4-7k which is too much.
  6. travelers
    travelers Senior Member
    2,925
    59
    It could also be valve seals.
  7. brendan127
    Bad valve seals on a 27k mile 2012 mustang? That's known for #8 to go bad?
  8. LarryJM
    LarryJM forum member
    189
    I have seen some bad #8 pistons and they do look sad. What?? white smoke, black smoke, blue smoke? Truck engines seem to be 1/2 Mustang engines at junkyards. I found a 10K mile example for $2000. For sure it can't be fixed in the car.
  9. stkjock
    36,925
    441
    I guess thy could possibly pull the rod and piston from the bottom, but it’s rare that it can be done
  10. Gabe
    Gabe Whippled Coyote
    6,982
    219
    Built short block ...
  11. travelers
    2,925
    59
    Yea on second thought the compression wouldn't be low. Brain fart......
    brendan127 likes this.
  12. Marble
    Marble forum member
    701
    21
    There could be all sorts of carnage and until its torn down you will never know. I thought I had only a bad thrust bearing, but the bad bearing ended up toasting all but one rod. The crank shifted and ruined the block... etc etc.
    Point being you never know what is really wrong until its torn down. By going the route of only replacing rings on #8, I would almost guarantee the cylinder needs honing and ot would not work. Cheaper would be more expensive in the long run.
