itsslow
- Joined
- Jun 6, 2012
- Posts
- 1,041
- Reaction score
- 0
Some members off the forum are asking me for instructions on painting wheels, if you saw my last thread you'll know what I mean. Please have patience with me, as I'm not too good with giving instructions or educating people.
What you need:
Small air compressor
Compressed Air Paint gun
A pint of whatever paint you choose (A pint was just enough for my wheels and I did about 5 coats)
Paint reducer
Clear (You're going to use about a cup and a half)
Paint Hardener
6 of the 350 sand paper
10 of the 1000 sand paper
5 Colored towels
Wax and tar remover (From autozone right next to the paint and
laquer thinner, come in a black bottle like buffing compound)
Paint mixing stick
About 10 large foam cups
Purple Power (Autozone)
Almost everything can be bought at a car's paint store. If you don't know of one, call a local body shop and ask. I know a body shop can mix the paint for you, but I doubt they'll sell you the hardener and reducer.
YOU MUST TAKE YOUR TIME AND HAVE PATIENCE, IT TOOK ME THREE DAYS TO DO MY WHEELS AND I'M NOT COMPLETELY HAPPY WITH THE RESULTS!
Instructions:
I had wheels that were mildly scratched, but I wanted the best out of it. If you have a wheel that has deep scratches, I can't help you. Take it to the body shop and have them fill the scratches for you.
Go over the scratches with 350 sand paper until you can no longer feel the scratch, after you got all the scratches out, wet sand (Soap and water) the WHOLE wheel with 1000, and you have to do it well or the paint will not stick. Make sure you don't miss any spots!
Spray some degreaser (Preferably purple power) on the wheels, and scrub the wheels really good with a brush and then pressure wash. Make sure they are COMPLETELY dry, I'd let the sit over night!
Whenever you're ready to paint the wheels, make sure you wipe them down with wax and tar remover using the colored towels! Make sure you don't miss any spots!
Mixing the paint:
Go ahead and turn the compressor on and let it fill up with air. Get about 6 large foam cups, the paint, and the paint reducer out and move everything else out of your way.
The Paint:Reducer ratio is 2:1. Fill up half of the cup with paint, and then 1/4 of the cup with reducer. This should be enough for 2 wheels if you use wisely!
Before you do anything else, I'd watch a video on youtube on how to adjust and operate a spray gun
Pour the paint in the spray gun, and connect the gun to the compressor.
Go ahead and start spraying the wheel, if any of the paint drips or runs, you can TOUCH the running paint with a colored towel and paint over the spot you dried, IT WILL NOT SHOW!
Cleaning the paint gun:
Cleaning the gun is very important! If you don't clean it after painting whatever, the paint gun will ruin!
Pour some paint thinner into the gun (Same place you put the paint) and shake the gun, disconnect the spray gun from the compressor and pull the trigger on the spray gun, it should shoot a stream of the paint thinner, just do that until it stops. If it doesn't shoot the strea, connect it back into the compressor and then pull the trigger. Once you empty the paint thinner, disconnect the compressor again and do the first step over again, it should shoot a stream.
Let the wheels sit for at least 12 hours
Mixing the clear:
The ratio for clear:hardener is 4:1
Mix the paint, and then wipe the wheel with wax and tar remover, make sure you don't miss any spots!
Spray the wheel and make sure you don't miss any spots and spray the wheel COMPLETELY equally, if you spray more clear on one spoke than on another, it will stick out like a sore thumb!
Cleaning the paint gun again
Let the wheels sit for 24 hours, throw them on the car, and enjoy!
What you need:
Paint reducer
Paint Hardener
5 Colored towels
Paint mixing stick
Instructions:
Mixing the paint:
Mixing the clear:
