Procharger inlet pipe discolored
ProStang01
My inlet tubes have been discolored for some time and looking to clean or polish them for an upcoming car show. Anyone else have this problem and have a solution. Not sure if I should try neverdull or something like that??
Thanks
dabad1
pinehill al.
Procharger inlet pipes
I have the exactly the same problem I snatched mine off last night so I can get them powder coated black.
AMDanBailer
AmericanMuscle.com
Malvern, PA
Are you talking about the black plastic intake inlet or the silver intercooler pipes?
If it is the black inlet, use something like this:
http://www.autogeek.net/motbactrimca.html
or a similar bumper/trim restorer
If it's the silver intercooler pipe, I would wash it with soap and water/polish it and then wax it, just like you would the exterior of the car.
This will get it to repel the dirt/grime that is building up on it. It will also seal it from have the dirt stain it.
I hope this helps! Good luck!
ProStang01
It's the silver intercooler pipe. Thanks I will try that!
Dabad that's going to look killer powder coated black!
ProStang01
Pro, Check your PM box.
We have Optimum Metal Polish which can be used by hand.
Check out this link to see for it yourself, http://www.lethalperformance.com/ca...11322_11339/optimum-metal-polish-8-oz-p-37214
If you could post a picture so we can see the extent of the imperfections. I'm confident the optimum will work well for you. Don't forget, you can use your forum coupon for it as well.
Thanks John, soon as I can I'll snap a pic and post it. May be tomorrow. Thanks!
