I certainly don't have a fact based answer, but I wouldn't run it much over 400. You could probably go to 450ish with a BAP. But if I were you I would definitely make fuel system upgrades my next purchase.
The Kenne Bell boost a pump works very well.
But in 05 and 06 Ford had a recall on thier fuel pumps for a hesitation problem.
Just make shure you don't have one of the bad stock pumps.
Thats interesting as I had some hesitation problems from time to time while on leave driving my car. I thought it was just a tune thing and the fact that I haven't upgraded my fuel system yet and am running a bit high HP.
The stock pump with the bap will be fine but you will still have the possibilty to peak but to save yourself a hassle, Just buy yourself a gt500 pump. Spend alittle more but have a good system that will last.
HESITATION ON ACCELERATION AFTER LONG TSB 06-9-9 CRUISE FORD: 2005-2006 Mustang
ISSUE
WARRANTY STATUS: Eligible Under Provisions Of
Some 2005-2006 Mustangs may exhibit a hesitation
on acceleration after a long cruise. After coming to a stop from a highway type cruise, some vehicles may experience a hesitation when the customer begins to accelerate. Air bubbles can form around the fuel pump during a long cruise and be ingested into the pump on acceleration causing a hesitation. MT060909 Claim Additional Labor Actual ACTION
Required As Actual Time Time
Refer to Service Procedure for corrective action. Or Use SLTS Operation If
Available SERVICE PROCEDURE DEALER CODING CONDITION 1. Perform normal Workshop Manual (WSM), BASIC PART NO. CODE Section 303-04 diagnostics to isolate the 9H307 53 concern to the fuel pump. 2. Replace the fuel pump per WSM, Section 310-01. PART NUMBER PART NAME 7R3Z-9H307-C Sender And Pump Assy NOTE:
The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is available through Ford Motor Company’s on-line technical resources. Copyright
ã 2006 Ford Motor Company Online Publication Date April 28, 2006 PAGE 1
