alphableak83
I had steeda springs, lca arms, adjustable upper control arm, adjustable panhard bar, and upper strut mounts installed the other day. I am very pleased with the results except the toe couldn't be corrected to where it needs to be for the front. The left toe is .17 and the right toe is -.15 with the steer ahead .16, but the total front toe is .02. The upper strut mounts are maxed out as far as adjusting to get the toe correct. Do I need to get a bumpsteer kit to fix this or is there anything else I need to get? thanks.
