fake
2011 Black 5.0
I will let you know what I find out.
I don't think they even make a signature series that anyone with a gt500 would want either. At least I did not see anything for 5w50 or 10w40.
I know they recommend atf for the tr6060.
Redlines 5w50 has shown great results in the various analysis too.
So ive completed my fluid swap, I think I got more on the ground than in the transmission but it seems to be fine , so as for the changes!!! My trans was still warm and I went for a drive , there was a difference in selecting the gears 1,2,R specificly they were butter smoothe . So after sitting all night in the garage 45degrees I pull out this morning and it feels just as notchy as it ever has, first few shift were ugly as compaired to the night before. After a few miles it feels alright , being 35 outside I doubt it ever got warm on the 7 mile ride to work, I think the fluid swap has made a difference but best results will be at operating temp. Did anyone else when using the hand pump have fluid constantly spitting back out of the hole? This is the reason im hoping I have the propper fluid level in there, I know I used a roll of paper towels cleaning up . Also is there no good way to check fluid level besides knowing how much you put in? If you were not sure would it be ok to just fill it to the fill plug level?
So who here wishes they would have bought the auto instead? lol
Me but only because of my knee. LOL. The transmission shifts fine for me other than alittle notchiness.
Answer me this. The Amsoil MTG is the same weight as the QS fluid, so why would I see improved cold shifting when the MTL i'm using now is notchy until it gets warm? The MTL is super smooth during the summer, will I see the same with MTG? I don't want to have the same notchy shifting I had with the factory fill. I'm just concerned since the MTG is a heavier weight than MTL.
What makes the MTG better than the MTL, other than it's the correct factory spec?
Just curious, that's all.
