Wheels n cams 4 sale
shikwann
Madera, CA
Comp cams 127100 valve springs required. These offer a great increase in power throughout the mid to upper rpm range. These do not require a rear end upgrade. These cams drive just like stock with a slight change in idle.
These where removed with 4000 miles of use after a failed follower and because these are not smog legal I decided to not keep them because once repaired I'd have to remove them every 2 years for a smog check.
Upon replacing the the failed follower there was a damaged lobe on the passengers side cam. I took this cam to the local speed shop (advanced engines) and the shop owner said he can send it out to be fixed back to new for less than $100. Again there is only one cam lobe damaged that needs to be repaired.
These cams sell for $600 you can have them here for much less than that.
$240 shipped
I also have Gt500 wheels with tires that were plastic dipped in black. These are in great shape, one of them has rash about a thumbs length around the rim other than that you're good to go. Tires have low tread so they would need replacing in 5k miles or so. I prefer a local sale as shipping would be crazy expensive. These would make any GT look freakin sweet or even track wheels $630
Well you get the idea, they are a little dirty but they clean up nice, I'll snap a pic when cleaned up.
fordrocks
Miami,FL
Damn this would make for some sweet track shoes, wish these were local. Free bump.
