Wind sound coming through from driver side window
Elemayoh
California, MD
Don't know how to attach a video, it won't let me. I recorded the sound while driving. It only really happens at high speeds but it rarely occurs even at super low speeds. It's really loud and quite annoying.
I've noticed that if I press against the rubber seal from the inside while driving, with my finger, in a certain spot (right above the little triangle thing on the door that has the mirror controls) then the noise will stop as long as I have my finger pressed against it. I've looked at the rubber seal and I saw no holes. It all looks normal. I have no idea what's causing it at this point. I've tried super gluing a few gaps here and there where I thought it might be coming from, but no luck.
However I did stick some napkins tightly packed in the little pocket with the rubber seal and that fixed it for a bit, but one rainy day later, the napkins got soggy and the noise returned. I really don't want to have to buy another rubber seal but I guess I have to at this point.
I also glued where the seal connects, thinking it was maybe a little gap between the body and the rubber but yeah that didn't do anything.
I'm so confused because there's no holes in the seal itself, it's completely intact.
