Got my kit installed, and I'm trying to wire up the window switch.. I'm not real clear on where I wire the tach wire to. I know there's power, ground, tps, but where does the tach wire go ?? Anybody know ?
you can use a fuel injector or cop for wiring.... each fi will have a "common" wire.. it will be the same color on each plug... the other wire is the "trigger" wire..it will be a different color on each plug... its the wire the ecm controls... you wanna use the tigger wire... the fi and cop have different colored wires but you get the idea. i used a fi for mine and it worked perfect.
