Terry
I did 4.10 gears last year, my mechanic is ocd and very good.
I ordered Ford racing gears as I heard they were the best and new bearings. He could not get them quiet after 10 hours and a couple visits, we ended up finding some metal in the oil and machining marks in the gears (finish was not smooth)
He explained to me that years ago a set of gears were quite expensive and with them being so cheap now the quality has gone down.
I ended up ordering a new set and he put them in, these did not have the finish issue and are dead quiet. He also explained that he had to re shim a lot and that normally you do not need to if swapping the same ratio gears further emphasizing the lack of tolerances in modern gears. I've heard several other similar accounts.
With that all said, being you know your mechanic is good, if the first try with the Ford racing gears is not quiet it may be worth trying a second set before settling on 3.73s
I have had FRPP 4.10's in my 06 for the last 60K miles and have never had any whine at all out of them. Just had my local ford dealer install them and never had any issues
Good luck with resolving your gear whine Terry!
I tackled my first ever gear install January 2015, also Ford Racing 4:10's. Experienced installers told me my patterns looked pretty good but I ended up with a deceleration or coasting whine as you describe. Fortunately I have been able to live with the noise so far but I will likely take the car to an expert sometime this year.
My coat pattern:
Drive pattern:
Hi, Terry,
If you installed control arms with spherical bearings, the metal on metal action will telegraph any differential noise easily through the floorpan and into the cabin. I learned this the hard way in my '11 GT, and ended up replacing aftermarket spherical bearing items with polyurethane stuff to get rid of the noise. If you really love the 4.10's, I'd suggest you replace the spherical bearings, as well.
Guys,
I appreciate all your feedback just so you know.
I was not going to post the following as I have read that some members don't like my long, drawn-out, wordy posting.
In this situation and some of you taking the time to give me your feedback I think I owe it to you to tell the complete story on mine regarding gearing.
The story goes like this,
Back in 2011 I went to my local guy to have him take out the 3.73 gears he had installed at an earlier time.
(He was a Master Technician at a Ford Dealership and then left and started his own business)
He also had installed Ford Racing 4.10 gears before in mine.
So, he had over the years since back in 2008 when I ordered the Bullitt installed 4.10 gears as well as 3.73 gears.
I had switched back and forth between them with no problems and no real noise issues from the gearing.
But ..............
Back to 2011 when I went to him to once again take the 3.73 gears out and install the Ford Racing 4.10 gears.
And yes he had the complete kit that included everything to do the job.
It was all ordered by me from American Muscle.
The kit was actually for a GT-500 rear-end as that's what comes in the 08 Bullitt Mustangs.
Well he did his thing and guess what ???
Major gear whine right off the bat and only driving it right down the street.
So I call American Muscle and they send out another set of the Ford Racing gears, (No-Charge).
They are installed and the same thing once again major gear whine at even low speeds driving it right down the street.
So, this time I call and ask to speak directly to a Manager at American Muscle.
I explain the situation to him and he says, I'll send another set out to you at No-Charge.
Right now we are out of them but expecting a new shipment in a few days.
Sure enough he does exactly as he said he would another set of Ford Racing 4.10 gears arrive.
And a UPS pick-up slip for the gears being removed.
Guess what guys ???
I and a buddy of mine were both right there watching the complete process take place.
We saw the gear mesh with the dye and it all looked very good.
It went back together and off I went with my buddy down the street to test for gear whine.
Same exact thing as the other times.
With each set of gears you would either have excessive gear whine on deceleration or acceleration.
So I told my guy to remove the 4.10 gears and I was done !!!
I was not all pissed off at him as I knew he was good at doing this as he had done it so many times over the years with no noticeable gear whine.
I call the manager at American Muscle and we have this time a lengthy discussion so that just maybe we could get to the bottom of why this was happening when it never did in the past.
He made some calls and called me back and come to find out that Ford was No-Longer making their gears.
Motive was making them to Ford's Specifications.
So, I said I have an idea as mine now is so LOUD it is simply not going to be derivable on the street.
I was looking at my options on-line and I see you guys have complete Ford Racing GT-500 Rear-End-Assemblies.
He said yes we do and they can be ordered with either 3.55 gears or 3.73 gears.
I said let me make a call to Brenspeed Engineering & Performance in Pierceton, IN as they are a retailer of your's.
He said yes they are, we know them and they do a lot of business with us.
I said let me make a quick call to Brent White the owner of Brenspeed and I'll call you right back and we can hopefully get a workable plan together.
I called, talked to Brent, he said just have American Muscle drop-ship the complete rear-end-assembly to us.
I called the Mgr. at American Muscle back and we agreed on them drop shipping a complete rear end assembly to Brenspeed for my Bullitt.
Well guys I took the Bullitt to Brenspeed back in 2011 and George Dockery made the switch.
So the above is what took place back in 2011 and I have been {Paranoid} to even think about changing the 3.73 gears to the 4.10's again.
But, DBR Performance right here where I live does some extremely high-end vehicles and have done several things for me on mine.
As well as some of my local buddies using DBR.
I decided to have a talk, lengthy talk actually with David the owner of DBR.
I explained the exact same story I just have said above.
He felt like John his shop Mgr had so much experience setting up rear-ends it would not be an issue.
John worked for another company prior to DBR and he did rear-end gear changes weekly.
So he has years and years of experience in doing this sort of thing.
John felt like that going with Richmond Gears was a better choice as in his opinion they had the very-best-tolerances.
Well, guess what, noise at 60 plus MPH if you were not on the gas and it was in between accelerating or off the gas on a grade in decelerating.
Totally unacceptable ............
So to continue David made some calls as well as John at DBR before they went with the Richmond Gears.
They found out that if you could find a set of Ford Racing Gears with an A on the suffix they were produced by Ford.
If there was an M in the suffix they were produced by Motive to Ford's specifications.
So that's another reason why John went with the Richmond gears the 1st time.
They could not find a set of the Ford Racing gears with the A suffix when they had the person actually look at the boxes the gears were in.
If any of you have taken the time to read all of what I have said above and then below you will more understand what's going on I think.
I'll do a complete informative post once I get the call from DBR Performance that mine is ready to be picked up.
Truthfully, I really doubt that the Ford Racing 4.10 gears are going to be quiet.
(I'm not saying they have to be Perfectly Quiet but livable without Excessive Whine)
I think all the suspension changes on mine is simply allowing way to much feed back from the rear-end to up in the cabin.
If I had the stock rubber mounts and not all the polyurethane bushings and did not have the BMR rear
Xtreme Anti-roll Bar Kit, Rear, Hollow 35mm
That is welded to the rear axles so transfers all noise right to the cabin.
The New GT-500 complete Rear-End-Assembly below:
So I'm thinking there is no-longer anything stock remaining under mine suspension wise to help isolate the rear-end noise.
Terry
